12436 Discussions
How to set Speed: 100 Mbits full duplex instead oft Auto-negotiation on DE2-115 board
Hello Friend's
I have altera De2-115 board ....i want set speed: 100 mbits full duplex instead of auto-negotiation
How do i do this task ?.
Kaushal
You'll need to write to the PHY's mdio registers. Register 0 is the control register, where you can disable autonegotiation and force 100Mbps speed.
IEEE 802.3 Clause 22 contains the full details of this register, but here's the register contents:
15 - reset
14 - loopback
13 - speed lsb 6,13 = 01 for 100mbps
12 - aneg enable
11 - power down
10 - isolate
9 - restart aneg
8 - duplex, 1 = full, 0 = half
7 - collision test
6 - speed, msb
5 - unidirectional enable
4:0 - rsvd (0)
For 100Mbps, full duplex:
1010 0001 0000 0000
or, 0xA100
Are you positive you want to disable autoneg? If you connect the board to a device that is configured for auto-negotiation, it will parallel detect and you'll get a duplex mismatch. You could also configure the device to advertise 100Mbps only, but still use autonegotiation. You can do this via register 4 (and don't forget to hit the soft reset bit in register 0 after making any changes in register 4). If you have a 10/100/1000 PHY and you want to disable advertising for 1000BaseT, you'll also have to configure register 9.
where is the location of PHY's mdio registers. & control register, or how could i write the mentioned value in these registers.
Is it in file altera_avalon_tse.c ..?
line no. 1573 (for auto-negotiation ) and
line no 1830 (for speed)
Once you have configured the TSE MAC with the correct PHY address (register mdio_addr0 or mdio_addr1, described on page 6-5 of the TSE's datasheet) the MDIO registers are directly mapped as TSE registers (see MDIO space 0 and MDIO space 1 on page 6-2).
If you are using Altera's driver with the Interniche TCP/IP stack, after initialization the PHY address is already set up in mdio_addr1 so you can directly access the MDIO registers in MDIO space 1.
