12435 Discussions
How to sned more than 32bits of data to HPS form FPGA custom ip
down votefavorite (http://stackoverflow.com/questions/43377035/read-data-from-the-fpga-ip-to-the-hps-in-altera-soc-fpga...
I am trying to access data from hps via Avalon memory mapping interface. I have put together system in qsys and assigned base address. In below code the I got the count value in 1st 32 bit std_logic_vector data to the HPS. But I didn't get the data in second 32 bit std_logic_vector
library ieee;
use ieee.std_logic_1164.all;
USE ieee.numeric_std.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity en is
GENERIC(
max_pulse : INTEGER := 800; --pulses per revolution
res_bits : INTEGER := 16); --max count 2^res_bits
port(
--avlon slave inputsa and outputs
clk : in std_logic;
reset : in std_logic;
avs_s0_address : IN STD_LOGIC;
avs_s0_read : IN STD_LOGIC;
avs_s0_write : IN STD_LOGIC;
avs_s0_readdata : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
avs_s0_writedata : IN STD_LOGIC_VECTOR(31 DOWNTO 0)
end en;
architecture behavior of encorder is
----- avlon read
PROCESS(avs_s0_read)
BEGIN
IF avs_s0_read = '1' THEN
CASE(avs_s0_address) IS
WHEN '0' => avs_s0_readdata <= x"0f0ff0f0";
WHEN '1' => avs_s0_readdata <= x"0f0fffff";
WHEN others => avs_s0_readdata <= x"00000000";
END CASE;
ELSE avs_s0_readdata <= x"00000000";
END IF;
END PROCESS;
The way I access data from the HPS is as below,
# define COUNT 0xFF200020 //Avalon base Addrs +counter base Addrsint
main(void){
volatile int * Count_ptr = (int *) COUNT;
unsigned int cnt, ex;
while(1) {
cnt = *(Count_ptr);
ex = *(Count_ptr+1);
printf("count = %d \n",cnt);
printf("count = %d \n",ex );
0down votefavorite (http://stackoverflow.com/questions/43377035/read-data-from-the-fpga-ip-to-the-hps-in-altera-soc-fpga...
I am trying to access data from hps via Avalon memory mapping interface. I have put together system in qsys and assigned base address. In below code the I got the count value in 1st 32 bit std_logic_vector (count) data to the HPS. But I didn't get the data in second 32 bit std_logic_vector (count_n)
