HI all,
Does anyone know how to suspend a running application during a debug session? Regards, Kwok WongLink Copied
You need to highlight the "Nios II Elf Debugger ..." line or the "Thread [0] ... "in the Debug window.
After you do this, the 'Suspend' (2 vertical yellow bars) and 'Terminate' (red square) icons at the top of the window will become active. You can then click on the Suspend icon to suspend the debugger. -- Terry
