Who can tell me how to use custom linker script file? What 's the path of the system library project folder? I use Nios II 9.1 SP2. Thank you.
You'll find a file named generated.x in this directory:
\<your_project_name>_syslib\Release\system_description This is the default linker script file. Copy this into \<your_project_name>_syslib , possibly renaming it as <your_project_name>.x Change what you need in the script file which should now appear in that selection dialog in syslib properties.
