12435 Discussions
How to use "i2c_opencores_sw.tcl" in I2C (OpenCores)?
Altera wiki provides i2c core from opencores:
http://www.alterawiki.com/wiki/i2c_%28opencores%29
The core supports the qsys. There is an "i2c_opencores_sw.tcl" inside the folder. I believe I can use this to update the bsp (to add the i2c HAL to bsp) in nios II eclipse when I develop software. But how can I run this tcl in Nios II eclipse?
I try to run it through Nios II command shell:
nios2-bsp --script i2c_opencores_sw.tcl
But it gives me errors as screenshot, why?
_sw.tcl files are used by nios2-bsp-editor
Open nios2-bsp-editor
Look at the "Driver" tab of the GUI.
The "Driver Name" for the I2C component should be something other than "none". This means that the BSP editor found the _sw.tcl and assigned that driver to the hardware block for you.
When you generate the BSP, the driver .h and .c files will be included in your build and you can invoke the functions from your application.
--- Quote Start ---
--- Quote End ---
Thanks, ted. I checked the Nios II BSP Editor and I can see the driver of the i2c is "none". I think this means the _sw.tcl has not been excuted properly. How can I fix this problem?
Where should I put "_sw.tcl" file? When I open the bsp editor, in the software packages tab, I can't see this tcl file.
The _sw.tcl belongs in the same search path as the _hw.tcl you used to create your Qsys system. So if you just unzip the .zip and have added the I2C to your Qsys, then the _sw.tcl is probably in the right place.
It looks like the problem is that for whatever reason, in the files in the .zip, the _hw.tcl and _sw.tcl don't agree on the name of the hardware block.
In the _hw.tcl, the name is "i2c_opencores" [like it says on the wiki page].
In the _sw.tcl, the expected name is "opencores_i2c".
Try changing the _sw.tcl so that:
set_sw_property hw_class_name i2c_opencores
And then restart the bsp-editor
--- Quote Start ---
--- Quote End ---
You are right. in _sw.tcl, all "i2c_opencores" was mistaken to "opencores_i2c", even the source codes names. After I changed all of them, it works and the drivers are generated in bsp.
Thanks so much for help.
