I want to use the i2c protocol for implementing the seven segment display in max10 Board.can anyone one help in sending any reference code of this
There is no certain example of displaying a seven segment display with NIOS but it is a very simple example.
You can create an RTL code to get the value from NIOS and then translate it to 7 segment display. The NIOS can send the seven segment value to the following circuit and the value will be displayed as seven segment.
always @*
begin
case(seven_seg_val)
4'b0000: LED_out = 7'b0000001; // "0"
4'b0001: LED_out = 7'b1001111; // "1"
4'b0010: LED_out = 7'b0010010; // "2"
4'b0011: LED_out = 7'b0000110; // "3"
4'b0100: LED_out = 7'b1001100; // "4"
4'b0101: LED_out = 7'b0100100; // "5"
4'b0110: LED_out = 7'b0100000; // "6"
4'b0111: LED_out = 7'b0001111; // "7"
4'b1000: LED_out = 7'b0000000; // "8"
4'b1001: LED_out = 7'b0000100; // "9"
default: LED_out = 7'b0000001; // "0"
endcase
end
another option is to this into the C/C++ code by using switch case for example to translate the value to 7-seg
There are many examples online you can find like the following:
Hii sir,
can you send some link which could be helpful for me.
Can you send the process how to proceed . Actually first time working with nios ii. So unable to figure out.
Thank you
Ritu
