12604 Discussions
How to write/read data to DDR in NIOS II eclipse tool ?
Yogesh
suppose I have an array of data as below
array[10000] = {1,2,3,4,5...................10000};
How to write this data in 10000 address locations of DDR?
Please reply with a sample code
Eliath_G_Intel
Hi Yogesh!
The way for doing this depends on what you're using :
Do not hesitate to let me know any questions you may have .
Regards!
-Eliath Guzman
Yogesh
Hi Eliath,
I am interested in the 2nd design (FPGA DDR)which you mentioned.
I went through the design provided by you . But I didn't find the c code( NIOS eclipse code) which is used to store data in DDR .Am I seeing something wrong?
I just want to understand (code wise) how data is written to FPGA DDR using Eclipse c code.
Please guide me.
Thankyou
Yogesh
Yogesh
document of 2nd link(FPGA DDR) is not accessable.
Eliath_G_Intel
Hi Yogesh,
Hoping you're doing well, I wonder if I can close this thread,
I found another post of you with almost the same question and I've seen
my colleague gave you a solution.
Is there anything else I can do for you?
-Eliath
