12599 Discussions
How use altera_avalon_fifi_xxx with a .cpp file ?
I try to use altera_avalon_fifo_init() function in .cpp file extension.
The compilation is OK but the linker does't find the function defined in bsp (in library libhal_bsp.a). The error is :
c:\dev\e111\fpga\fit\software\test06/other1.cpp:9: undefined reference to `altera_avalon_fifo_init(unsigned long, unsigned long, unsigned long, unsigned long)'
But, when I rename the file with .c extension, all is ok.
Is it possible to use altera_avalon_fifo_init() (or any functions in BSP) into .cpp file ?
I use Eclipse Indigo. My project is created with "Nios II Application and BSP from Template"
Best regards
Eric
I remember that if you define a function (i.e. testcpp() ) in a cpp file, you must declare it with the extern "C" directive in order to call it from a .c files.
extern "C" int testcpp (int n);
int testcpp (int n)
/* function body */
I think you must use something similar for calling .c functions from .cpp source files.
Hi Cris72,
Thanks a lot. Now all is OK.
Best regards
Eric
