When it comes to external memories to store configuration data, we have the following options:
1. EPCS. 2. EPCQ. 3. CFI Flash. 4. Quad SPI. 5. NAND Flash. If I have a design containing NIOS, how would I put the HW (that comes from .sof) + SW (that comes from .elf) images into a single image to program any of these flash memories? What steps are needed? Are the steps the same for them?Link Copied
For EPCS, you would use the EPCS Serial Flash Controller Core IP block and use a JIC programming file.
For the parallel and SPI flash, I believe you are looking at multiple images needed.- Mark as New
i do create my epcs images using the following commands from the Nios Command Shell:
sof2flash --epcs --compress --input=hw.sof --output=hw.flash
elf2flash --epcs --after=hw.flash --input=sw.elf --output=sw.flash
Now i do have 2 flash files which are combined via:
cat hw.flash sw.flash > image.flash
And converted to epcs binary
nios2-elf-objcopy -I srec -O binary image.flash image.bin
Now your image.bin can be wriiten directly to address 0 of your epcs, or to another address if you use the Remote_Config IP. I do not have any experience concerning the other Flash types, but think there's an equal approach.
Topic Options
