12603 Discussions
I Can not run my Nios II program, because of "Project does not have an ELF file"
FZhan39
Hello,friends
there is a problem when i used Nios II, "project does not have an ELF file, Please make sure project has been built successfully",
Do anyone kown this issue?
Ahmed_H_Intel1
8192 Bytes is small for an application, please let me know what device family you are using? I normally start with 64000 Bytes and see if the application will fit or not.
Ahmed_H_Intel1
What is the size for your on-chip memory that been vectored as reset memory and exception memory? if it is not an on-chip memory please let me know. It is mainly the size isn't enough or the bsp setting isn't the correct setting for the chosen memory.
FZhan39
It is on chip memory,and the size as following:
RAM on chip is 8192bytes
ROM on chip is 8192bytes
I tried to set the size of RAM and ROM is 4096bytes, but the issue is still..
FZhan39
Ahmed_H_Intel1
FZhan39
The FPGA is Cyclone 10, I have solved the issue by increasing the RAM.
Thank you so much!
Ahmed_H_Intel1
You are welcome , I will consider this case is closed.
