12603 Discussions
I lost my LCD in Quartus 4.2 and Nios 1.1
Hello all,
I went ahead and made the leap to 4.2 and nios 1.1.... there was a little churn in so far as updating the LAN AND CF components / s/w to 1.1, but I was able to get back to where I was before the upgrade The only thing I have left to baseline is the lcd display, it doesn't work.
Is there an updated LCD component and or s/w available for the lcd in 4.2 / 1.1?
Murph
please check the bdf you are using. Make sure you update it and see if any pins changed.
sorry to have wasted your time kerry.... the RS and RW pins were swapped.... I'll make sure I put something worthy out next time.
I'd rather have a user error than a real problem! Easier to fix on my side :-)
