12603 Discussions
IORD_XDIRECT AND IOWR_XDIRECT?
Hello:
Now I have some problems about the I/O Marco IORD_XDIRECT AND IOWR_XDIRECT.For example:
I have a 16 bits slave periphery and the BEn0 ,BEn1 are both always low(means that the upper 8 bits and the lower 8 bits are both used).Make sure the front point no problem,now I use the sentense IOWR_8DIRECT (base,odd_addr,data8),the result I think is that the upper 8 bits is the data8,the lower 8 bits
is xxxxxxxx.If using even address,the result is opposit.But I am not sure it is right or wrong?
I look up "io.h" which define the "IORD/IOWR", and then "stb / stbio, lbu/lbuio....." in the Instruction Set Reference of NIOSII. I can't understand the specification about those instructions.
Can someone help us to explain what they work out detailly?
Look at Table 3.5 of the Processor Reference Handbook
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
ldbio
ldbuio
stbio
ldhio
ldhuio
sthio
These operations load/store byte and half-word data from/to peripherals without caching or
buffering.[/b]
--- Quote End ---
Hi mountain8848,
The stb and stbio are used to store a byte (from memory). The stbio instruction
bypasses the data cache, the stb does not.
The ldbu and ldbuio are used to load a byte (from memory). The lduio instruction
bypassess the data cache, the ldbu does not. The "u" just means that the
high-order bits in the target register are set to zero (unsigned) rather than
being sign-extended.
--Scott
