Community
cancel
Showing results for
Search instead for
Did you mean:
Valued Contributor III
IOWR Macro to access 64-bit QDRII
32-bit Nios II is intended to access a 64-bit QDRII using IOWR and IORD macros. Can anyone tell me how should I do this? Noticed that now the access is as such:-
32-bit nios ii writes to 64-bit qdrii and 64-bit qdrii writes to 72-bit afi
Carid
Highlighted
Re: IOWR Macro to access 64-bit QDRII
Just a guess: I know that there is IORD_32DIRECT(), maybe such macro for 64bits? 🙂
Highlighted
The Nios CPU always sees its data space as 32 bits so a 64-bits read/write operation will have to be split up into two 32-bit operations.
