I am not able to get USB mass storage to work with ISP1362 on DE2-70 board I followed the instructions at http://www.alterawiki.com/wiki/usbhost applied the fix described at http://www.alteraforum.com/forum/showthread.php?t=18752 and successfully compiled the project and linux when boot it seems that the driver and mass storage support is loaded gooddriver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd: ISP1362 Host Controller
isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1
isp1362-hcd isp1362-hcd: irq 2, io mem 0x096091a0
isp1362_hc_start:
isp1362-hcd isp1362-hcd: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100
isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200
isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680
isp1362-hcd isp1362-hcd: USED/FREE: 3968 128
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: ISP1362 Host Controller
usb usb1: Manufacturer: uClinux 2.6.30 isp1362-hcd
usb usb1: SerialNumber: isp1362-hcd
usb usb1: configuration# 1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ISP1362 Host Controller, irq 2
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
Anyway if I connect USB key, or mobile phone with mass storage support its not communicating with the device, but USB is probably activated because its charging the phone over it. Can you help please? Thank You
I am still not able to figure it out,
can someone help please? Thank You
