12600 Discussions
If I want to put software program elf file into flash, do I need a flash controller?
If I want to put software program elf file into flash, then the system can load program automatically after power on, I think I need to add a flash controller in my qsys system, correct? Is Altera Avalon Flash the right IP I should use/
Anyone has idea?
Thanks in advance.
ok i am working on the same project , i am a beginner , i used the avalon tristate conduit components , but dunno whether it is the answer ,
in any way this links will answer you too
http://www.alteraforum.com/forum/showthread.php?t=44414&highlight=flash
:oops:
sincerely ,
Nobody has experience?
Altera supplies some libraries for writing the epcs/epcq devices from software if the avalon epcs controller IP is instantiated. One way to discover the correct elf offset is to run elf2flash with the --after option.
--- Quote Start ---
--- Quote End ---
Thanks. Do you mean "EPCS Serial Flash Controller Core"?
--- Quote Start ---
--- Quote End ---
yes, that's the one we use here
--- Quote Start ---
--- Quote End ---
Thanks very much.
