I have a C code written that uses kiss_fft (fast fourier transform). http://sourceforge.net/projects/kissfft/ The code runs just fine using Eclipse IDE. But when I run the same code using DS-5 (Cyclone 5 SoC), in one of the kiss fft function, the if statement is executed even though the condition is false. It is not supposed to. And then there is a segmentation fault (SIGSEV signal 11). if (st->inverse) phase *= -1; From the attached images, st->inverse has the value 0. So the if condition is false and should not enter the loop but it does so regardless. I do not understand why. Anybody has had the same issue? or any suggestions? Thanks.Link Copied
