Igor Mac, DP83848 and tcpdump
Hi all,
could you somebody advice me with my problem ?
I have design (in attachement) - NIOS2, SDRAM, ethernet (igor mac) with zImage and when i boot kernel and use ifconfig eth0 192.168.2.2 and use ping, it is ok.
But when i ping to my pc (ping 192.168.2.200) it finished with 100% loss packet and NIOS2 dont read data ok - when i read ifconfig statistics - all reading packet are dropped. In wireshark i read arp packet, pc answer, but uclinux send again arp packet, because dont read packet well and try it again.
Setting of dp83848 looks ok - the same like in development kit, where it works.
When i see this on oscilloscope, it looks ok. Where could be error ? on design or on the board ?
Does anybody build tcpdump or some another tool for reading arp packet ?
Thank you very much.
Jan Naceradsky, Czech Republic
You can build tcpdump for Nios II. It's included in uClinux-dist. You can (may need to) update it to the latest version by extracting the source in user/tcpdump/tcpdump-4.x.x and changing the Makefile to point to that version.
When i turn on
[*] tcpdump and use make, it finished with these mesagges:
make[1]: Leaving directory `/home/uclinux/nios2-linux/linux-2.6'
if [ -f /home/uclinux/nios2-linux/uClinux-dist/linux-2.6.x/vmlinux ]; then
ln -f /home/uclinux/nios2-linux/uClinux-dist/linux-2.6.x/vmlinux /home/uclinux/nios2-linux/uClinux-dist/linux-2.6.x/linux ;
fi
. /home/uclinux/nios2-linux/uClinux-dist/linux-2.6.x/.config; if [ "$CONFIG_MODULES" = "y" ]; then
[ -d /home/uclinux/nios2-linux/uClinux-dist/linux-2.6.x/modules ] || mkdir /home/uclinux/nios2-linux/uClinux-dist/linux-2.6.x/modules;
make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- -C /home/uclinux/nios2-linux/uClinux-dist/../linux-2.6 O=/home/uclinux/nios2-linux/uClinux-dist/linux-2.6.x modules;
fi
for dir in lib user ; do [ ! -d $dir ] || make ARCH=nios2 -C $dir || exit 1 ; done
make[1]: Entering directory `/home/uclinux/nios2-linux/uClinux-dist/lib'
[ -z "" ] || make -j1 || exit $?
[ -z "" ] || (cd /home/uclinux/nios2-linux/uClinux-dist/staging; chmod 755 ./usr/lib/lib*.so*; chmod 644 ./usr/lib/lib*.la ./usr/lib/lib*.a; sed -i -e "/^libdir=/s:=.*:='/home/uclinux/nios2-linux/uClinux-dist/staging/usr/lib':" -e "/^dependency_libs=/s: /usr/lib/: /home/uclinux/nios2-linux/uClinux-dist/staging/usr/lib/:g" ./usr/lib/*.la; sed -i "/^prefix=/s:=.*:='/home/uclinux/nios2-linux/uClinux-dist/staging/usr':" ./usr/lib/pkgconfig/*.pc ./usr/bin/*-config; true)
[ -z "libpcap" ] || make -j1 libpcap || exit $?
make[2]: Entering directory `/home/uclinux/nios2-linux/uClinux-dist/lib'
[ ! -d "libpcap" ] || ( touch libpcap/.sgbuilt_lib && make -C libpcap ) || exit $?
make[3]: Entering directory `/home/uclinux/nios2-linux/uClinux-dist/lib/libpcap'
make -C build
make[4]: Entering directory `/home/uclinux/nios2-linux/uClinux-dist/lib/libpcap/build'
nios2-linux-uclibc-gcc -O2 -O2 -g -fno-builtin -I. -I.. -DHAVE_CONFIG_H -D_U_="__attribute__((unused))" -c ../pcap-linux.c
In file included from ../pcap-linux.c:78:
./config.h:189:28: linux/autoconf.h: No such file or directory
./config.h:190:29: config/autoconf.h: No such file or directory
../pcap-linux.c: In function `pcap_open_live':
../pcap-linux.c:274: error: structure has no member named `timeout'
../pcap-linux.c:336: error: structure has no member named `sock_packet'
../pcap-linux.c: In function `pcap_read_packet':
../pcap-linux.c:474: error: structure has no member named `cooked'
../pcap-linux.c:522: error: structure has no member named `sock_packet'
../pcap-linux.c:536: error: structure has no member named `lo_ifindex'
../pcap-linux.c:559: error: structure has no member named `cooked'
../pcap-linux.c: In function `pcap_inject_linux':
../pcap-linux.c:716: error: structure has no member named `sock_packet'
../pcap-linux.c:718: error: structure has no member named `ifindex'
../pcap-linux.c:728: error: structure has no member named `cooked'
../pcap-linux.c: In function `pcap_setdirection_linux':
../pcap-linux.c:1023: error: structure has no member named `sock_packet'
../pcap-linux.c: In function `live_open_new':
../pcap-linux.c:1384: error: structure has no member named `sock_packet'
../pcap-linux.c:1397: error: structure has no member named `lo_ifindex'
../pcap-linux.c:1412: error: structure has no member named `cooked'
../pcap-linux.c:1449: error: structure has no member named `cooked'
../pcap-linux.c:1484: error: structure has no member named `ifindex'
../pcap-linux.c:1485: error: structure has no member named `ifindex'
../pcap-linux.c:1488: error: structure has no member named `ifindex'
../pcap-linux.c:1498: error: structure has no member named `cooked'
../pcap-linux.c:1510: error: structure has no member named `ifindex'
../pcap-linux.c:1534: error: structure has no member named `ifindex'
../pcap-linux.c: In function `pcap_close_linux':
../pcap-linux.c:1675: error: structure has no member named `clear_promisc'
../pcap-linux.c:1715: error: structure has no member named `next'
../pcap-linux.c:1724: error: structure has no member named `next'
../pcap-linux.c:1729: error: structure has no member named `next'
../pcap-linux.c: In function `live_open_old':
../pcap-linux.c:1765: error: structure has no member named `sock_packet'
../pcap-linux.c:1768: error: structure has no member named `cooked'
../pcap-linux.c:1843: error: structure has no member named `clear_promisc'
../pcap-linux.c:1849: error: structure has no member named `next'
../pcap-linux.c: In function `fix_program':
../pcap-linux.c:2022: error: structure has no member named `cooked'
make[4]: *** [pcap-linux.o] Error 1
make[4]: Leaving directory `/home/uclinux/nios2-linux/uClinux-dist/lib/libpcap/build'
make[3]: *** [all] Error 2
make[3]: Leaving directory `/home/uclinux/nios2-linux/uClinux-dist/lib/libpcap'
make[2]: *** [libpcap] Error 2
make[2]: Leaving directory `/home/uclinux/nios2-linux/uClinux-dist/lib'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/uclinux/nios2-linux/uClinux-dist/lib'
make: *** [subdirs] Error 1
But the main question is - if i have error on design - sopc builder or schematic design in Quartus ... or is there any errors on the board - with DP83848 etc. ?
Thanks for your opinions.
Jan
If you mean the compile error -- it's not related to the FPGA/SOPC design. You should be able to build any of the user applications and libraries regardless of of the FPGA design.
If you mean your actual problem -- yes it's very likely it's the design, but if you are not using the latest version from Linux "nios2" branch then it could likely also be the software. I don't know anything about the Igor MAC though.
Thank you,
but yesterday I finally found the error - it was in SOPC builder in Open Cores 10/100 Ethernet MAC Avalon - Igor Mac, which has 3 parameters:
Total descriptors: 128
TX Fifo size in bytes: 128
RX Fifo size in bytes: 4096
It must be 4096, when it was 128, data was not read.
Although i didn´t make tcpdump, i change open_eth.c to debug mode and in this mode the kernel print RX and TX data from/to ethernet chip. (in attachment)
Driver for igor_mac with debug print.
