I'm trying to invoke an interrupt for some buttons on my DE2-115 EVM but I constantly getting the following warning (not error) about the 'alt_irq_register' command:
Description: Implicit declaration of function 'alt_irq_register' [-Wimplicit-function-declaration]
]Resource: hello_world.c, Path: /Interrupt_sw, Location: line 200, Type: C/C++ Problem]
I did (attached herewith) almost exactly as written in the C Example in the " Nios II Software Developer’s Handbook"," Chapter 8: Exception Handling", pages: 8-6 and 8-7.
What could possibly be the reason for that warning? (Again, I did exactly as Altera's example…)
Idan
I believe this warning shouldn't appear.
Is your code running as expected? or this warning affects the code?
Yes. the code is running as expected but with the warning.
Can/ Should I do somthing to make this warning disappear?
Idan
