I am using NIOS II 10, and i am using in my code includes.h.
The problem is that while compiling the nios couldnt discover or find the path of the includes.h... so i tried to add manually to the project but i recognized that i need dozens of file to add.. includes.h: no such file or directory the related code that i have the syntax error in os_stk task1_stk[task_stacksize];
alt_u32 canirq0 = canif_0_irq; so i think the includes.h will solve the problem... Is there a way to add this header files from directory or smth...i think this will solve my problem
Compiler include paths are added to the project properties:
Here's how: Right-click the project, choose 'C/C++ Build', Tool Settings tab, the General node on the NIOS II Compiler branch. You can add compiler flags and set optimization levels here as well. Bill Ait worked with me but after adding four paths.... i got 36 errors from ucos_ii.h
like: c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_suspend_en: include code for ostasksuspend() and ostaskresume()" then another error:error: `alt_irq_not_connected' undeclared here (not in a function) So i dont know if i miss paths or smth wrong.
You have to modify os_cfg.h for your application. It found the# includes. Now it's not happy about the configured contents.
Bill Athe project that i am working on is already existed and tested. i just want to open, build, and then run it on my pc to see the output.
another big problem that I am not familiar with C and i dont know how to configure this file.... So do you have any advices?--- Quote Start --- the project that i am working on is already existed and tested. i just want to open, build, and then run it on my pc to see the output. --- Quote End --- Then that project should have it's own local uC/OS-II files and an OS_CFG.h already configured. If as you say you have a project already done then it should still build now unless the files that are# included are not the same. Search for other OS_CFG.h files. Bill A
i asked the one who created the project and he sent me the ucos_ii.h and os_cfg.h and i found that they are the same like mine. He told me that he didnt include any path for his project. BUT for me i had to add the files manually to remove the errors.
SO it is really weird that we have the same files and everything and i have thses c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_arg_chk_en: enable (1) or disable (0) argument checking" blank_project_mah line 1783 1286796718005 919c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_cpu_hooks_en: uc/os-ii hooks are found in the processor port files when 1" blank_project_mah line 1788 1286796718005 920
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_debug_en: allows you to include variables for debugging or not" blank_project_mah line 1798 1286796718005 921
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_flag_en: enable (1) or disable (0) code generation for event flags" blank_project_mah line 1438 1286796718005 896
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_lowest_prio: defines the lowest priority that can be assigned" blank_project_mah line 1803 1286796718005 922
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_max_events: max. number of event control blocks in your application" blank_project_mah line 1808 1286796718005 923
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_max_tasks: max. number of tasks in your application" blank_project_mah line 1642 1286796718005 902
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_mbox_en: enable (1) or disable (0) code generation for mailboxes" blank_project_mah line 1480 1286796718005 897
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_mem_en: enable (1) or disable (0) code generation for memory manager" blank_project_mah line 1514 1286796718005 898
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_mutex_en: enable (1) or disable (0) code generation for mutex" blank_project_mah line 1540 1286796718005 899
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_q_en: enable (1) or disable (0) code generation for queues" blank_project_mah line 1562 1286796718005 900
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_sched_lock_en: include code for osschedlock() and osschedunlock()" blank_project_mah line 1817 1286796718005 924
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_sem_en: enable (1) or disable (0) code generation for semaphores" blank_project_mah line 1612 1286796718005 901
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_change_prio_en: include code for ostaskchangeprio()" blank_project_mah line 1675 1286796718005 907
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_create_en: include code for ostaskcreate()" blank_project_mah line 1679 1286796718005 908
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_create_ext_en: include code for ostaskcreateext()" blank_project_mah line 1683 1286796718005 909
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_del_en: include code for ostaskdel()" blank_project_mah line 1687 1286796718005 910
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_idle_stk_size: idle task stack size" blank_project_mah line 1659 1286796718005 903
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_name_size: determine the size of task names" blank_project_mah line 1691 1286796718005 911
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_profile_en: include data structure for run-time task profiling" blank_project_mah line 1827 1286796718005 925
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_query_en: include code for ostaskquery()" blank_project_mah line 1699 1286796718005 913
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_stat_en: enable (1) or disable(0) the statistics task" blank_project_mah line 1663 1286796718005 904
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_stat_stk_chk_en: check task stacks from statistics task" blank_project_mah line 1671 1286796718005 906
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_stat_stk_size: statistics task stack size" blank_project_mah line 1667 1286796718005 905
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_suspend_en: include code for ostasksuspend() and ostaskresume()" blank_project_mah line 1695 1286796718005 912
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_task_sw_hook_en: allows you to include the code for ostaskswhook() or not" blank_project_mah line 1832 1286796718005 926
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_tick_step_en: allows to 'step' one tick at a time with uc/os-view" blank_project_mah line 1837 1286796718005 927
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_ticks_per_sec: sets the number of ticks in one second" blank_project_mah line 1709 1286796718005 914
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_time_dly_hmsm_en: include code for ostimedlyhmsm()" blank_project_mah line 1713 1286796718005 915
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_time_dly_resume_en: include code for ostimedlyresume()" blank_project_mah line 1717 1286796718005 916
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_time_get_set_en: include code for ostimeget() and ostimeset()" blank_project_mah line 1721 1286796718005 917
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_time_tick_hook_en: allows you to include the code for ostimetickhook() or not" blank_project_mah line 1842 1286796718005 928
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h# error "os_cfg.h, missing os_tmr_en: when (1) enables code generation for timer management" blank_project_mah line 1731 1286796718005 918
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h error: `os_lowest_prio' undeclared here (not in a function) blank_project_mah line 736 1286796718005 893
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h error: `os_max_tasks' undeclared here (not in a function) blank_project_mah line 756 1286796718005 895
c:/altera/10.0sp1/nios2eds/components/micrium_uc_osii/ucosii/inc/ucos_ii.h error: `os_task_idle_stk_size' undeclared here (not in a function) blank_project_mah line 748 1286796718005 894
so maybe there is smth in the options of the project...i dont really know... Does anyone know what to do or try??
I had the similar problem. I forgot to select RTOS. To do this
Right click project -> System Library Properties Here you can select an RTOS from dropdown.For more complete information about compiler optimizations, see our Optimization Notice.
