Incompatible SD-Cards
I have tried to prepare a new SD-card and I ran into a problem:
- I use the Socrates-board
- I have used the image from the website (socrates-training.tgz)
- The SD-card was prepared on different Linux-PCs (Ubuntu in VM, Ubuntu on Microserver)
- The SD-card was connected with a USB-to-SD-adapter (Transcend)
- The script was running with success
When I install the SD-card in the socrates-board, nothing happens..
This was reproducible with two SD-cards:
- Transcend 8GB, SDHC, Class 4
With the SD-card, shipped with the Socrates-board, everything is fine, but this is the same card, but another supplier:
- Toshiba 8GB, SDHC, Class 4
When I use another Transcend-card, it works also:
- Transcend 16GB, SDHC, Class 10
Is this a known issue?
Thanks and best regards,
JoAs
Is the problem still happen If create via window system?
