I'm attempting to use an Ubuntu 14.04 virtual private server to build the kernel, distro, and bootloader.
When I try to install the 16.0 EDS I get an error because it is looking for xterm or a gnome-term. I don't need/have graphics. How can I install the toolchain without the DS5 IDE? Also, I'm a little confused. I'm assuming the baremetal tools are for the bootloaders. Which toolchain is used for Linux userspace code? Thanks, Kenny --- Quote Start --- Launch DS-5 installation [Y/n]: Info: Failed to run ds-5 Installer, no xterm or gnome-terminal found. Press [Enter] to continue: Error: Error running xterm -e '/opt/altera/16.0/embedded/ds-5_installer/install.sh --destination /opt/altera/16.0/embedded/ds-5': /bin/sh: 1: xterm: not found Press [Enter] to continue: Info: The baremetal toolchain link was not created. You need to run /opt/altera/16.0/embedded/host_tools/altera/ds5_link/ds5_link from the embedded command shell after installing DS-5 to create the baremetal toolchain link. Press [Enter] to continue: Vulture: Vulture: Vulture: Vulture: ls /opt/altera/16.0/ embedded/ licenses/ logs/ qprogrammer/ uninstall/ Vulture: ls /opt/altera/16.0/ embedded/ licenses/ logs/ qprogrammer/ uninstall/ Vulture: ls /opt/altera/16.0/embedded/ ds-5_installer/ examples/ embedded_command_shell.sh host_tools/ embeddedsw/ ip/ env.sh version.txt Vulture: ls /opt/altera/16.0/embedded/embedded_command_shell.sh /opt/altera/16.0/embedded/embedded_command_shell.sh Vulture: /opt/altera/16.0/embedded/embedded_command_shell.sh WARNING: DS-5 install not detected. SoC EDS may not function correctly without a DS-5 install. --- Quote End ---Link Copied
