Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Install older version of GCC compiler for HLS
I'm following the intel® high level synthesis compiler getting started guide for the Linux version it states that GCC compiler must be version 4.4.7 and newer ones are not supported.
I'm running Ubuntu 16.04 LTS and gcc version is 5.4.0.
How can I install the 4.4.7 version?
Thank you.
I have installed it from Ubuntu trusty repositories. I don't know if this is the optimal solution but it worked.
edit the apt sources file: sudo nano /etc/apt/sources.list
add the trusty repo at the end: deb http://us.archive.ubuntu.com/ubuntu/ trusty universe
reload the sources: sudo apt-get update
install gcc 4.4: sudo apt-get install gcc-4.4
