Hi to all, I've a bunch of registers managed with our internal bus protocol, so we should insert a Avalon MM bridge to translate our protocol .(It is a propietary bus protocol used by our company in several FPGA projects)
I've a question , the instantiation of this map of registers could be done with instantiation in a custom Qsys IP ? Could you give me an example of interfacing HPS with an custom IP in logic (it is a bank of several registers, about 2000 registers with different addresses not contigous), I need an example similar with a bunch of registers. Also this interface should be accessed by Hard Pcie Avalon MM. So we have 2 masters that control the registers, the HPS and Pcie , this arbitration is done by Qsys interconnect , of course . Best RegardsLink Copied
