I am using a Cypress CY7C09289V-12A SRAM on my prototype FPGA board. I wish to use this for my NIOS II code. I have added a SRAM (IDT71V416S) and a tristate bridge to my qsys and have connected them accordingly. I had to change the address and data widths to match my SRAM. Then i have assigned the appropriate pins in my Quartus. For this IC i have enabled ADS_n signal and disabled CNTRST_n signal. I have given a 40 MHz clk to the IC I am getting "Downloading ELF process failed" when i try to download the NIOS II code from Eclipse. Kindly let know what could i be doing wrong ? regds SanthoshLink Copied
The first step would be to add some on-chip memory to your Nios system and put there a memory test software (there is one in the templates list). Then use that software to test the SRAM
This board which am using is not an altera board. Its a prototype board for our purpose.
Moreover which templates are u telling about ? This is urgent, if someone could help, it would be helpful regds santhosh- Mark as New
In Eclipse, when you create a new software project, there is a memory test template.
