12604 Discussions
Interniche and 2 eth interfaces
I try to put in service the second eth interface on my HW.
Interniche data structure should support several eth interface but it's not clear how i can custumize the sw.
For example is S91_DEVICES define shows the number of eth interfaces? Now, I must modify S91_DEVICES from 2 to 1 for handling two eth interface and modify the get_mac_addr() and get_ip_addr() so to retrieve the correct value in according with the correct eth instance.
Modify also s91_port_prep() in according to system.h file for HW address.
Is correct? is sufficent only this or I need to customize other data structure or function?
thnaks...
Altera has not tested interniche+NIOS II with more than 1 eth interface so ... I've a dubt..is It possible configure Iniche for 2 or more Eth interface?
In the standard Iniche SW suite included in "Eclipse packet" I see a comment about that the stack is able to handling only one eth.
Someone as found a similar problem ?????
