Interrupt in uC/OS-II
I use OSSemPost in my Interrupt ISR as follow:
volatile int frame_ready_edge_capture; INT8U error_code; static void handle_frame_ready_interrupts(void* context, alt_u32 id) { /* Cast context to dval_edge_capture's type. * It is important to keep this volatile, * to avoid compiler optimization issues. */ volatile int* frame_ready_edge_capture_ptr = (volatile int*) context; /* Store the value in the dval's edge capture register in *context. */ *frame_ready_edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(FRAME_READY_IRQ_PIO_BASE); /* Reset the dval's edge capture register. */ IOWR_ALTERA_AVALON_PIO_EDGE_CAP(FRAME_READY_IRQ_PIO_BASE, 0); /* * Read the PIO to delay ISR exit. This is done to prevent a spurious * interrupt in systems with high processor -> pio latency and fast * interrupts. */ IORD_ALTERA_AVALON_PIO_EDGE_CAP(FRAME_READY_IRQ_PIO_BASE); error_code = OSSemPost(FVSendVideoDataSem); alt_uCOSIIErrorHandler(error_code, 0); FrameDown= 1; IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, led0^=1); //IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, led0+=1); frame_ready_edge_capture= 0; }
and in my Task:
void SendVideoTask() { INT16U rgb_tx_buf_cnt= 0; INT16U cntTCPFrame= 0; INT16U cntVideoFrame= 0; INT32U Data_Pixel; INT16U Data_Pixel_16bit; alt_u8 dot, Dot, packet= 0, DotCnt= 0; INT8U error_code, led= 0; alt_u16 x, y; ..... ..... OSSemPend(FVSendVideoDataSem, 0, &error_code); alt_uCOSIIErrorHandler(error_code, 0); for(y= 0; y<RAW; y++) { for(x= 0; x<COL; x++) { Data_Pixel= IORD_MY_RGB2YUV_IP_DATA(MY_RGB2YUV_BASE); // read 24bit RGB value Dot= Data_Pixel; // isolate B Dot= Data_Pixel >> MY_RGB2YUV_IP_DATA_G_OFST; // isolate G Dot= Data_Pixel >> MY_RGB2YUV_IP_DATA_R_OFST; // isolate R Dot= Dot >> 3; // make 5bit for Blue Dot= Dot >> 2; // make 6bit for Green Dot= Dot >> 3; // make 5bit for Red Data_Pixel_16bit= 0; Data_Pixel_16bit |= Dot << 11 | Dot << 5 | Dot; // merge all in 16bit RGB value alt_up_pixel_buffer_dma_draw(pixel_buf_dev, Data_Pixel_16bit, x, y); // draw pixel on VGA for debug } }
the LED_PIO works well, but my Interrupt with OSSemPost in the ISR and OSSemPend in my Task dosn't work.
Could someone say me what I mak ewrong???
Antonio
I watch wrong in the Signal Tap II, my code work good....
sorry
You must write ones, not zeros, in order to clear edge capture and acknowledge the irq.
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(FRAME_READY_IRQ_PIO_BASE, 1);
Otherwise the irq would continuously retrigger.
I suggest to disable the interrupt first and re enable it at last with [h=2]alt_irq_enable(IRQ number)[/h]
This will avoid re-triggering problem and make sure that ISR executed successfully
