12603 Discussions
Interrupt on my radar application - what have I been programming ?
Dear Forum users,
I implemented with verilog a simple 32 bit wide COUNTER. Then I read the counter out with
Nios and I implemented on my radar application two switches - one switch for starting the
radar pulse and one switch for displaying the result on the RS232. Now the code it functions
but I do not know what I have been implementing with version 9.1.
The code will look as follows:
//PAVLE DUKANOVIC
//www.dukelanovic.com
//Neckarrems,19.10.2014
//RS232 COMMUNICATIONS
# include<stdio.h># include<string.h># include "altera_avalon_pio_regs.h" # include "alt_types.h"# include "unistd.h" # include "system.h"# include "sys/alt_irq.h"
# define seg *(volatile unsigned char *) SEG_BASE # define bit *(volatile unsigned char *) BIT_BASE # define RESET *(volatile unsigned char *) RESET_BASE# define TRIG *(volatile unsigned char *) TRIG_BASE# define COUNTER *(volatile alt_u32 *) COUNTER_BASE# define START *(volatile alt_u32 *) START_BASE
const alt_u8 duan[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
// 0 1 2 3 4 5 6 7 8 9
alt_u8 num[8] = {0,0,0,0,0,0,0,0};
alt_u8 number[8];
alt_u32 n = 0;
alt_u8 key_flag;
alt_u8 key_flag1;
volatile int edge_capture;
void key_ISR(void* context, alt_u32 id)
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(START_BASE,0);
IORD_ALTERA_AVALON_PIO_EDGE_CAP(START_BASE);
key_flag = 1;
void key3_ISR(void* context, alt_u32 id)
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(K3_BASE,0);
IORD_ALTERA_AVALON_PIO_EDGE_CAP(K3_BASE);
key_flag1 = 1;
void key_Init()
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(START_BASE,0xF);
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(START_BASE,0x0);
alt_irq_register(START_IRQ,NULL,key_ISR); //START_IRQ 3
void key3_Init()
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(K3_BASE,0xF);
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(K3_BASE,0x0);
alt_irq_register(K3_IRQ,NULL,key3_ISR); //START_IRQ 3
// This function will display 8 Numbers
void display(alt_u32 i)
alt_u8 j;
num[0] = ((((((i % 10000000)%1000000)%100000)%10000)%1000)%100)%10;
num[1] = ((((((i % 10000000)%1000000)%100000)%10000)%1000)%100)/10;
num[2] = (((((i % 10000000)%1000000)%100000)%10000)%1000)/100;
num[3] = ((((i % 10000000)%1000000)%100000)%10000)/1000;
num[4] = (((i % 10000000)%1000000)%100000)/10000;
num[5] = ((i % 10000000)%1000000)/100000;
num[6] = (i % 10000000)/1000000;
num[7] = i / 10000000;
for(j=0; j<8; j++)
bit = ~(0x01 << j);
seg = duan[num[j]]; // here the display is switched on
usleep(100);
number[7] = ((((((i % 10000000)%1000000)%100000)%10000)%1000)%100)%10+0x30;
number[6] = ((((((i % 10000000)%1000000)%100000)%10000)%1000)%100)/10+0x30;
number[5] = (((((i % 10000000)%1000000)%100000)%10000)%1000)/100+0x30;
number[4] = ((((i % 10000000)%1000000)%100000)%10000)/1000+0x30;
number[3] = (((i % 10000000)%1000000)%100000)/10000+0x30;
number[2] = ((i % 10000000)%1000000)/100000+0x30;
number[1] = (i % 10000000)/1000000+0x30;
number[0] = i / 10000000+0x30;
int main ()
char* msg = "M01 ";
FILE* fp;
key_Init();
key3_Init();
printf("RS232 DEMO : \n");
fp = fopen (UART_NAME, "r+"); // here we initialize the RS232 port
RESET = 1;
TRIG =1;
while(1){
n = COUNTER;
display(n);
usleep(100);
if(key_flag){
TRIG = 0;
usleep(10);
fwrite (msg, strlen (msg), 1, fp); // here we write on the RS232
usleep(40000);
key_flag = 0;
TRIG = 1;
if(key_flag1){
fwrite (number, strlen (number), 1, fp); // here we write on the RS232
key_flag1 = 0;
return 0;
Can you tell me where I can find a good reference about programming and handling interrupts?
What have I been doing with the initialisation of my interrupt?
void key_Init()
What do those commands mean ?
Please help me.
This document has a C code explaining it. The content is present on pg 8-15.
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/nios2/n2sw_nii5v2.pdf
I hope you enabled interrupts while creating your system in qsys and did give the right priority to the different components.
