12455 Discussions
Interrupts from HPS peripherals
Board : DE-10 ( Cyclone V SoC )
OS : FreeRTOS
Hi, I'm writing a driver for FreeRTOS+TCP stack. I configured the EMAC1 and DMA peripherals.
At this moment, everything works fine, except that I don't get any interrupt from EMAC1.
So for the moment I poll the EMAC and DMA status bits. I see them come high, and I can clear them by writing 1's.
What I did is :
● Program the GIC to enable interrupt 152 ( ALT_INT_INTERRUPT_EMAC1_IRQ )
● Set the handler + data
● Set a priority and trigger level
● program the peripheral ( EMAC interrupt mask reg 15, and EMAC/DMA interrupt enable DMA register 7 )
As a test, I tried to get interrupt from UART-0. The device works fine, but I don't see interrupts neither.
The only interrupt that does work is interrupt 29 ( ALT_INT_INTERRUPT_PPI_TIMER_PRIVATE ). That timer is used to get a FreeRTOS system clock.
I asked the same question on the FreeRTOS forum, but without success.
See https://sourceforge.net/p/freertos/discussion/382005/thread/a80a5ff7/?limit=250#d738
The problem is solved.
I had to call:
alt_int_dist_target_set( ALT_INT_INTERRUPT_EMAC1_IRQ, (alt_int_cpu_target_t) 0x01);
in order to direct the EMAC1 interrupts to the first core.
That call will set "Interrupt Processor Targets Registers", which start at 0x800 of the GIC.
Regards.
