Ioctl problem
I'm writing a device driver and I have problems with the ioctl function. When I run my user application associated with the driver in the terminal, "printks" that are inside my module functions appeared in a wrong order, I use "printk" to know where I am. Besides "printk" that are inside ioctl code of the module appeared without having make a call of ioctl. Maby the computer has reorganized the order of the instructions and ioctl always starts when I run a new application?
I have used in my user code a file_pointer instead of a file_descriptor, althought I have used function fileno to have a file_descriptor because it is one of the paremeters of the function ioctl.
I don't know how to solution these problems.
Code_User_Application
FILE *leds; . . . printf("Fitxer obert Usuari\n"); descriptor_leds=fileno(leds); fwrite(Dada,sizeof(char),1,leds); ioctl(descriptor_leds,LEDS_IOCSETD,&Dada_ioctl); printf("IOCTL_Usuari_Superat\n\n");Module_Code
static int Leds_ioctl(struct inode *inode, struct file *file, unsigned int cmd, unsigned long arg){ static int data; printk("\nSuper_ioctl\n"); printk("Valor_cmd:%d\n",cmd); switch(cmd){ case LEDS_IOCSETD: if (copy_from_user(&data,(int *)arg, sizeof(int))) return -EFAULT; printk("Ioct_Valor: %d\n",data); return 0; default: printk("Ioctl_Cap_opcio\n"); return -ENOTTY; } }Thanks
Do you have a doubt for the printing order of 'Super_ioctl....' and 'Fitxer obert Usuari...'?
If so, please consider that the 'printf' messages are all buffered and wait the timing to send to your console.
Kazu
Hi:
I suggest that add sleep(1) after printf("Fitxer obert Usuari\n");
I‘m sure module has higher priority than app。。
Thanks for answers.
But I was referring to "printks" that are in functions of my module no "printfs". I mean in my user code I make a call of function fwrite before calling function ioctl and in the terminal I saw "printks" of ioctl before printks of fwrite and all "printks" that I have written in the module have the same priority. And also why "printks" of ioctl can appear in terminal if I don't make a call of function "ioctl", I have chosen a unique magic number.
Thanks in advice
Would you please write the order of printk's message that you are expecting?
Kazu
Thanks for help. Well I think that the order of "printks" should be this:
//Printk function fwrite Copy_from_user: 4 I'm here //Printk function Ioctl Super_ioctl Valor_cmd:1 Ioctl_Valor1: 5These are "printks" that I think that should appear in terminal with this order and only these "printks". I would like to understand where are mistakes.
Thanks a lot.
--- Quote Start ---
--- Quote End ---
Where did you put 'printk' inside of 'fwrite'? The 'fwrite' is only a library function, not a kernel function.
Kazu
Maby I'm wrong but I'm not agree with you. It's true that 'fwrite' is a function of <stdio.h> library , but it is connected with my kernel function write.
One of the parametres of fwrite is a file_pointer, this file_pointer has the same major as my driver, so when I call a fwrite in user space indirectly I call my function write in kernel.
Things ara litle complex but more or less.This what I think, maby I'm wrong tell me please.
AFAIK, you can't use fwrite() (or anything from stdio.h) in Kernel code.
-Michael
We are mixing things. I know that I can't use fwrite in kernel code Michael, I 'm using it in user application as I explained in my first post. But I used this function fwrite in user application to call my function write in the kernel code.
The problem is the order of printks.
Thanks for the pacience
--- Quote Start ---
--- Quote End ---
Maybe you wrote next codes somewhere in your kernel.
printk("Copy_from_user:%d\n", **); printk("I'm here\n"); And where? That is the problem.
Kazu
