Hii Everyone,
I've been looking everywhere and could not find any correct resources to help me. I designed Ethernet board with Cyclone V(5CSEBA5U19A7N) using Quartus 15.1 Prime Standard. I am using KSZ9031RNX ethernet chip in my Board. I strucked in environment before linux kernel.In environment my ethernet chip is not detected.In place of my ethernet chip(KSZ9031RNX) it shows ethernet chip(KSZ9021RNX). /******************************************************** micrel-ksz9021-clk-skew=0xf0f0 micrel-ksz9021-data-skew=0x0 ********************************************************/ I am unable to observe MII status .It didnt show anything related mii . /----------------------------------------------------------------------------- Environment size: 2555/4092 bytes SOCFPGA_CYCLONE5# mii info SOCFPGA_CYCLONE5# ------------------------------------------------------------------------------/ I generated preloader and u-boot.img in SOC Embedded Shell by using MAKE and MAKE UBOOT commands. My question is ...How to generate uboot.img to show my MII status and to detect my ethernet chip(KSZ9031RNX).. If anyone knows related to my querry.please inform me. Thanks in advance. Regards. ChethanLink Copied
Hi Chethan,
You need to properly define the# defs in altera specific header files. In the Uboot check the below file: uboot-socfpga/include/configs/socfpga_common.h This heard file contains the# def for board specific PHY indication. # define CONFIG_PHY_MICREL_KSZ9021 So it assumes the board contains that specific PHY. Hope you have already figured this out. It might be useful for some one else who end up here :) Regards, Sunil
