12603 Discussions
Kernel Panic programing fpga from Linux
Hello Community,
I receive the following error when I want to program the fpga from Linux:
fpga_manager fpga0: writing fpga.rbf to Altera SOCFPGA FPGA Manager Unable to handle kernel NULL pointer dereference at virtual address 00000008
The full kernel log is in attachment: kernel-log.txt
The device tree is in attachment: device-tree.txt
The kernel defconfig is in attachment: kernel-deconfig.txt
Device-tree overlay file is in attachment: dtso.txt
I hope u can help me. Thanks in advance.
I use buildroot 2018.05 to build the device-tree, the kernel and all the rest for a Linux Embedded device.
I tried the following kernel versions: rel_socfpga-4.9.78-ltsi_18.07.01_pr and rel_socfpga-4.16_18.06.02_pr from https://github.com/altera-opensource/linux-socfpga but both have the same error.
I think I found a workaround.
This error is caused by
dtc -O dtb -o /tmp/dtbo -@ "$DTSO_FILE" cat /tmp/dtbo > /sys/kernel/config/device-tree/overlays/default/dtbo
Piping the content of the dtbo seems not to work anymore.
The solution is to pipe the name of the dtbo file to the path argument of device-tree overlay.
dtc -O dtb -o /lib/firmware/dtbo -@ "$DTSO_FILE" echo dtbo > /sys/kernel/config/device-tree/overlays/default/path
