Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Kernel boot hanging after power-up
I'm having trouble with a custom board when booting Linux.
After the FPGA configures, the kernel begins to boot, and hangs when trying to mount the second RAMdisk. If I RESET the processor without reconfiguring the FPGA, the kernel boots, and the system runs without any problems. This is the output to the terminal. Do I have to change the kernel source to account for 64 MB of SDRAM?
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 047F0000
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 512 (order: 9, 8192 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory available: 63104k/65536k RAM, 0k/0k ROM (1473k kernel code, 306k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x85020bd0 (irq = 0) is a jtag_uart
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 4 RAM disks of 4096K size 1024 blocksize
smc_probe: 100000 Khz Nios
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
eth0: SMC91C11xFD(rev:1) at 0x85000300 IRQ:18 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07
:ed:00:00:00
eth1: SMC91C11xFD(rev:1) at 0x85010300 IRQ:19 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07
:ed:00:00:00
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
CF: ctl=0
Altera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bank
Intel/Sharp Extended Query Table at 0x0031
Using buffer write method
cfi_cmdset_0001: Erase suspend on write enabled
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Altera NDK partition definition
Creating 4 MTD partitions on "Altera NDK flash (AMD)":
0x00400000-0x00800000 : "romfs/jffs2"
0x00200000-0x00400000 : "loader/kernel"
0x00000000-0x00200000 : "User configuration"
0x00000000-0x00800000 : "safe configuration"
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
NET: Registered protocol family 17
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 64k freed (0x19c000 - 0x1ab000)
expand: from=/ramfs.img to=/dev/ram0
expand: from=/ramfs.img to=/dev/ram1
-- The kernel hangs at this point where I believe it's trying to mount /dev/ram1 as /tmp
-Gary
Highlighted
Re: Kernel boot hanging after power-up
It looks like you're using a custom board... I don't know much about hardware, but could it be that some of the peripherals may need to be held in reset a bit longer before they're ready for use?
In the meantime, maybe you can try throwing in a bunch of "echo" statements into your rc file to try and slim down where the problem is occurring?
