I am trying to launch the FS2 debug cons.ole from a version 9.1 NIOSII software build tool. Does anyone know how to do this, the FS2 check box has disappeared from the Debug Configuration Debugger tab. Thank you.Link Copied
Hi Pierre,
Looks like this feature does not exists any more in the SBT tools. You have to use the legacy NIOS IDE (see ww.altera.com.cn/literature/hb/nios2/n2sw_nii52002.pdf), which is still available in the 9.1 suite (you should have a shortcut to it in your start menu). Hope this helps. Regards.
