While trying to run debug configuration, ARM DS-5 is throwing license error. I had obtained the new license as per the document "ug_soc_eds.pdf". But still it is showing the Flexnet license error. http://www.alteraforum.com/forum/attachment.php?attachmentid=10723&stc=1Link Copied
" Cannot checkout an uncounted license within a Windows Terminal Services guest session"
This sounds like remote desktop is not supported for ARM ds-5 fixed license. I suggest you to check with ARM license team.- Mark as New
interesting license issue, is the problem solved after contact the ARM team?
