Linking a DLL using Nios2 IDE
I'm trying to link the FFTW library to an example based on the Hello_world template but in vain. Here's the error:
***[hello_world_2.elf] Error 1
obj/hello_world.o *In function 'main': undefined reference to 'fftw_malloc'
How do I link a DLL to a piece of code in Nios IDE?
Thanks for any help.
HI,
Regarding the same problem, if I specify the path of the library in "Project properties" and use linker flags -lfftw3, i get the following error:
(path) ... /nios2-elf/bin/ld cannot find -lfftw3
Any help is most welcome. Thanks!
