12602 Discussions
Linux with MMU acessing registers
Hello i need to acess my registers from userspace, i am developing a
critical timing application and i can't consider the time needed to
call the device driver and read my timestamp register.
I need to read my timestamp register from userspace, how can i do
that? I know that 0x8 is for uncached, therefore peripherals adresses
will have the 8 in the adress.
I am trying to use inl(0x000024e0 (my adress), 0);
however i get a segmentation fault... i tried to include io.h but with no sucess
# define inl(addr)
unsigned int __res;
__asm__ __volatile__(
"ldwio %0, 0(%1)"
: "=r"(__res)
: "r" (addr));
__res;
# define inb(addr)
unsigned int __res;
"ldbio %0, 0(%1)"
: "=r"(__res)
: "r" (addr));
__res;
# define outl(b,addr)
"stwio %0, 0(%1)"
: : "r"(, "r" (addr));
# define outw(b,addr)
"sthio %0, 0(%1)"
# define outb(b,addr)
"stbio %0, 0(%1)"
Please don't cross-post between the mailing list and the nios2-dev list. Or if you do so, please at least link put a link to the other, so people searching for answers to the same or similar questions can find it in the other place too.
As already stated on nios2-dev, this won't work (for obvious reasons). Please see http://article.gmane.org/gmane.linux.uclinux.nios2.devel/189 for the full answer.
Okay, is there any easy way to acess the list archive?
Yes, there is. Either the mailman archive at http://sopc.et.ntust.edu.tw/pipermail/nios2-dev/ or at gmane (only massages since around beginning of june 2011): http://news.gmane.org/gmane.linux.uclinux.nios2.devel
This is my final code
memfd = open("/dev/mem", O_RDWR | O_SYNC );
if (memfd < 0)
log_msg("Cannot open /dev/mem\n");
exit(1);
pgoff = (unsigned int) (MENOS_BASE & (sysconf(_SC_PAGE_SIZE)-1));
map_len = 16 + pgoff;
mapped = mmap(NULL, map_len, (PROT_READ | PROT_WRITE),
MAP_SHARED, memfd, MENOS_BASE - pgoff);
if (mapped == MAP_FAILED )
log_msg("Cannot map registers\n");
ts_my = mapped + pgoff;
inl(ts_my);
