I am trying to run uclinux on DE0-Nano, and i successfully generated the zImage, but iam unable to load the image into SDRAM, it showing error like alex@alex:~$ nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage /opt/nios2eds/bin/nios2-gdb-server-wrapped: error while loading shared libraries: libjtag_client.so: cannot open shared object file: no such file or directory. Where is the mistake? Thanks in advance.Link Copied
- « Previous
- 1
- 2
- Next »
Myself added ,
1.mkdir /etc/jtagd cp /opt/quartus/linux/pgm_parts.txt /etc/jtagd/jtagd.pgm_parts 2.etc/rc.local---> /opt/quartus/bin/jtagd 3.empty file called .jtagd.conf created in home directory, even though same problem when i typed in terminal "jtagconfig" 1) USB-Blaster variant [7-1] Unable to lock chain (Insufficient port permissions) plz any help?- Mark as New
alex@alex:~$ cat /lib/udev/rules.d/51-usbblaster.rules
echo 'attr{idvendor}=="09fb", attr{idproduct}=="6001" mode="666"' ya its showing ,after that i reboot my machine also.- Mark as New
The rules file should not contain "echo". This means that you did not use the file from my zip archive at this post (http://www.alteraforum.com/forum/showpost.php?p=154547&postcount=9)
Use the file from the zip file to overwrite the existing 51-usbblaster.rules file and try again. N.- Mark as New
Now i changed the 51-usbblaster.rules files, but ....
alex@alex:~$ cat /lib/udev/rules.d/51-usbblaster.rules attr{idvendor}=="09fb", attr{idproduct}=="6001", mode="666" alex@alex:~$ jtagconfig 1) usb-blaster variant [7-1]unable to lock chain (insufficient port permissions)
Did you reboot after changing the file?
N.- Mark as New
ya, i reboot the system, but no use, same problem.........
That should have worked. Maybe you can try one of the other solutions from this thread (http://www.alteraforum.com/forum/showthread.php?t=5893).
N.- Mark as New
Really so sad, what i have to , y jtagconfig is not working , else can i try it under windows? any suggestions?
Thanks- Mark as New
In my case usb-blaster is working, in those posts they explained about usb-blaster on uubntu only, really i dont know , what i have to do, nearly one week , i tried but failed.
can i try it in windows? Thanks for ur suggestions.- Mark as New
You can always try running everything as root. Just type "sudo su" at the command prompt to become root (that way you don't have to type sudo everytime) and run jtagconfig.
N.- Mark as New
My /etc/rc.local is like ,
# !/bin/sh -e# # rc.local# # This script is executed at the end of each multiuser runlevel.# Make sure that the script will "exit 0" on success or any other# value on error.# # In order to enable or disable this script just change the execution# bits.# # By default this script does nothing. mount --bind /dev/bus /proc/bus ln -s /sys/kernel/debug/usb/devices /proc/bus/usb/devices /opt/quartus/bin/jtagd exit Thanks, Alex- Mark as New
If i run jtagconfig in root its showing error like
command not found.- Mark as New
Helo sir,
1)While rebootinng my os its showing the error an error occured while mounting /proc/bus/usb press s to skip or m for manual recovery. 2.alex@alex:/$ jtagconfig 1) usb-blaster [7-1]020f30dd ep3c25/ep4ce22 2)alex@alex:/$ killall jtagd jtagd(1154): operation not permitted
jtagd: no process found 3)alex@alex:/$ nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage there are no nios ii cpus with debug modules available which match the values
specified. please check that your pld is correctly configured, downloading a
new sof file if necessary.
and another error is /opt/quartus/linux/libstdc++.s0.6: version 'glibcxx_3.4.11' not found (required by /user/lib/i386-linux-gnu/libproxy.so.1) showing when i tried to open quartus
Where is the mistake ? kindly any help? Thanks, Alex. (http://www.alteraforum.com/forum/editpost.php?do=editpost&p=154758)
Did you upload an FPGA image before trying to upload the nios 2 software? If yes, where does this image come from?
Thanks for ur suggestions, and also thanks to nicocornelis,because he suggested mi in correct way to download image into sdram.
I need one help sir, Now i wants to work with DE2,DE4 with uclinux, kindly provide any tutorials Thanks, Alex.- Subscribe to RSS Feed
- « Previous
- 1
- 2
- Next »
