12603 Discussions
MAX10 project with Nios2
martim
i'm developing a project running on MAX10 and based on Quartus Prime Lite and win10 64bit. The project needs:
> some logic functions implemented in VHDL (tested, they work fine)
> a NIOS2 processor demanded to perform some low priority task (temperature control, read ADC, driving LEDS, signalling, and so on...). I need NIOS to have the possibility to fast adjust the code in C instead of passing through VHDL. Nios will need the IPs listed below...
- on chip memory
- i2c
- jtag uart
- parallel io
With Quartus Prime Lite i can only test the code running on my target board, right? Looking at the website it seems that i cannot program the MAX10 in order to get a "final device" able to running itself.
Is there the possibility to purchase some IP license in order to perform my task, keeping quartus lite software?
Am i missing anything?
I had a look at the website but i cannot identify if some of the IPs are the solution to my problem.
https://www.intel.com/content/www/us/en/programmable/products/intellectual-property/design/ip-base-suite.html
Thanks in advance.
EricMunYew_C_Intel
Hi, Montagna
Quartus Prime Lite is available for free, but it has limitation compared to Quartus Pro and Standard. You can find the details below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf
The IPs that you are looking for are available for free in Lite, and you can generate bitfile for your target board.
Eric
EricMunYew_C_Intel
Hi, Montagna
Can we close this ?
Eric
EricMunYew_C_Intel
Thanks Montagna.
