HI. I am trying to write a vhdl code for execution of a single clock cycle MIPS processor. But the .scf file is showing me unexpected results. Maybe I am missing something.
The ALU_result is not showing the write result fron the read register data, and PC is not branching. Someone please check it it below and see where I'm wrong. I am using bit 7 and 6 of the instruction to control the ALU. It needs to do only branch and add, and, + subtract. Thx R >> LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.STD_LOGIC_SIGNED.ALL; ENTITY Execute IS PORT( Read_data_1 : IN STD_LOGIC_VECTOR( 7 DOWNTO 0 ); Read_data_2 : IN STD_LOGIC_VECTOR( 7 DOWNTO 0 ); Sign_extend : IN STD_LOGIC_VECTOR( 7 DOWNTO 0 ); --ALUop : IN STD_LOGIC_VECTOR( 1 DOWNTO 0 ); Zero : OUT STD_LOGIC; Instruction : IN STD_LOGIC_VECTOR(7 DOWNTO 0); ALU_Result : OUT STD_LOGIC_VECTOR( 7 DOWNTO 0 ); Add_Result : OUT STD_LOGIC_VECTOR( 7 DOWNTO 0 ); PC_plus_4 : IN STD_LOGIC_VECTOR( 7 DOWNTO 0 ); clock, reset : IN STD_LOGIC ); END Execute; ARCHITECTURE behavior OF Execute IS SIGNAL Ainput, Binput : STD_LOGIC_VECTOR( 7 DOWNTO 0 ); SIGNAL OP : STD_LOGIC_VECTOR( 1 DOWNTO 0 ); SIGNAL ALU_output_mux : STD_LOGIC_VECTOR( 7 DOWNTO 0 ); SIGNAL Branch_Add : STD_LOGIC_VECTOR( 7 DOWNTO 0 ); BEGIN Ainput <= Read_data_1; -- ALU input mux Binput <= Read_data_2; OP < = Instruction(7 downto 6); -- Generate Zero Flag Zero <= '1' WHEN ( ALU_output_mux( 7 DOWNTO 0 ) = "00000000" ) ELSE '0'; -- Select ALU output ALU_result <= "000000" and ALU_output_mux( 7 DOWNTO 0 ) -- FLUSH WHEN OP = "11" ELSE ALU_output_mux( 7 DOWNTO 0 ); -- Adder to compute Branch Address Branch_Add <= PC_plus_4( 7 DOWNTO 0 ) + Sign_extend( 7 DOWNTO 0 ) ; Add_result <= Branch_Add( 7 DOWNTO 0); --************************************************************************************* PROCESS ( OP, Ainput, Binput ) BEGIN -- Select ALU operation CASE OP IS WHEN "00" => ALU_output_mux <= Ainput + Binput; WHEN "01" => ALU_output_mux <= Ainput and Binput; WHEN "10" => ALU_output_mux <= Ainput - Binput; WHEN "11" => ALU_output_mux <= Branch_Add;--branch; WHEN OTHERS => ALU_output_mux <= "00000000" ; END CASE; END PROCESS; END behavior;Link Copied
i fear this is the wrong forum part for this topic.
Hi Karsten.
Thx 4ur concern. Like I said the simulation was showing unexpected results, the was something wrong with my control signals for the ALU. But I managed to get it right now. Will post to the proper forum (of which I can't figure out another since this is software) in future. Sharp sharp...:cool:
