MP3 Player
Anyone, can help on this code.
I really don't understand why there are some many files inside a folder?
http://www.alterawiki.com/wiki/mp3_player
I try to load the existing source code to NIOS II.
When i try debug it, there are error message come out.
Anyone who know, please help?
did you compile the project first? Then if you select Run as Hardware it should find the .elf file for you.
Does it work with a simple hello world project?
Hi
I saw the same error when trying to run the project. The best solution: Create a new project and then add the source and header files from the MP3 player.
