MTD issue on the DE2-115
Hi Everyone,
Did anyone successfully running the uClinux and mount the mtd0 (8MB Flash memory) on the DE2-115? I tried to do the "flash_erase /dev/mtd0 0 3" and got error return message "No such device", then I realize it was never recognized from the bootup. I am sure I got my HDL wire correct and set it as a CFI flash component.
output wire [22:0] fl_address_out,
output wire [0:0] fl_read_n_out,
output wire [0:0] fl_write_n_out,
inout wire [7:0] fl_data_out,
output wire [0:0] fl_chipselect_n_out,
input wire fl_ready_busy_out,
output wire fl_RST_N_out,
output wire fl_writeprotect_n_out
As for the kernel setting, I followed the same configuration from http://www.alterawiki.com/wiki/mtd
The devicetree:
ext_flash: flash@0x10000000 {
compatible = "ALTR,cfi_flash-altera_generic_tristate_controller", "cfi-flash";
reg = < 0x10000000 0x00800000 >;
bank-width = < 1 >;
device-width = < 1 >;
# address-cells = < 1 >;
# size-cells = < 1 >;
ext_flash@10000000 {
reg = < 0x10000000 0x00000000 >;
}; //end ext_flash@10000000
}; //end flash@0x10000000 (ext_flash)
The system had been boot up from the jtag and test out the flash read/write capability until recently I wanted to use it as a storage device. :confused: I am suspecting it has to do with the device tree and it's driver since I had a simpler issue with the SPI for the SD Card before. I greatly appreciated if anyone can point me in to the right direction on this.
