12603 Discussions
Making Qsys Master Component
I was wondering if someone can send me a tutorial that indicates how to make an Avalon memory mapped master component in Qsys.
what is your master component? NIOS II ?
This one you are looking for?
http://www.mouser.com/pdfdocs/my_first_niosii.pdf
--- Quote Start ---
--- Quote End ---
Thanks for reply. No, I want to design my own custom master component. I don't want to use NIOS or HPS.
--- Quote Start ---
--- Quote End ---
I don't think there is any tutorial.
Altera gives you some example/templates you can follow: https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-avalon-mm.html
Beyond that, you're largely on your own. To save yourself some grief, I would recommend familiarizing yourself with the Avalon Verification IP and take the time to construct a good testbench. https://www.altera.com/support/support-resources/design-examples/design-software/simulation/exm-avalon-verification-ip.html
Depending on what you are trying to accomplish, the Modular SGDMA is another good resource to extend/borrow from: http://www.alterawiki.com/wiki/modular_sgdma
--- Quote Start ---
--- Quote End ---
Okay.. nothing much you can refer for custom designs., as I aware
--- Quote Start ---
--- Quote End ---
Thanks, I designed it. Actually it was quite easy.
--- Quote Start ---
--- Quote End ---
Hi
can you please help me with creating an avalon memory mapped master component please?
ThankYou.
