12600 Discussions
May I use tcp and udp simultaneously within a iniche stack
May I use tcp and udp simultaneously within a iniche stack?
how to implement? //create two task for each like the simple socket server?
thanks a lot for your help!
I have implement two tcp task,and it works well.
next: implement a tcp task and a udp task.
Sure, you can.
What's the problem? If you already implemented two tcp tasks, you only need to change one socket from SOCK_STREAM to SOCK_DGRAM
yes. I change the tcp socket to sock_DGRAM.
and I have implemented 1 tcp task and 1 udp task. and they worked well.
