I'm working to compile the application sample from Nios II Custom Instruction User Guide. I made the hardware setup and configuration with QSys without problem and I've programmed the BeMicro SDK board but I've a problem with the software application on Nios II EDS. After create the BSP project and application project I need to customize this defines for MEMORY_DEVICE_SIZE on crc_main.c but I don't know what values I need to use:
/* Change the name of memory device according to what you are using
* e.g.: DDR_SDRAM_0# #_SPAN
* SSRAM_0# #_SPAN
# define MEMORY_DEVICE_SIZE DDR_SDRAM# #_SPAN
Here I put the system.h section with the mobile_ddr_sdram's configuration and custom instruction's configuration made automatically by Nios II EDS using the sopcfile that I made using QSys. This file include the Custom Instruction CRC from the guide:
* mobile_ddr_sdram configuration
# define ALT_MODULE_CLASS_mobile_ddr_sdram mtx_avalon_sdram_mddr
# define MOBILE_DDR_SDRAM_BASE 0x4000000
# define MOBILE_DDR_SDRAM_IRQ -1
# define MOBILE_DDR_SDRAM_IRQ_INTERRUPT_CONTROLLER_ID -1
# define MOBILE_DDR_SDRAM_NAME "/dev/mobile_ddr_sdram"
# define MOBILE_DDR_SDRAM_SPAN 67108864
# define MOBILE_DDR_SDRAM_TYPE "mtx_avalon_sdram_mddr"
* Custom instruction macros
# define ALT_CI_CRC_0(n,A) __builtin_custom_ini(ALT_CI_CRC_0_N+(n&ALT_CI_CRC_0_N_MASK),(A))
# define ALT_CI_CRC_0_N 0x0
# define ALT_CI_CRC_0_N_MASK ((1<<3)-1)
I need that someone help me to know what value I need to use in the MEMORY_DEVICE_SIZE defines on crc_main.c. Thanks. Fabricio.
If I correctly understand your question, you only need to add MOBILE_ to the template define in order to match the name of your ddr device:
# define MEMORY_DEVICE_SIZE MOBILE_DDR_SDRAM_SPAN
