Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
Intel Support hours are Monday-Fridays, 8am-5pm PST, except Holidays. Thanks to our community members who provide support during our down time or before we get to your questions. We appreciate you!
Need Forum Guidance? Click here
Search our FPGA Knowledge Articles here.
Merged nios2 branch
From my Wiki reading I'm now in the current "nios2" branch where I should be able to work with MMU and non-MMU projects.
I've got a lot of old non-mmu projects so I wanted to start there before even trying the MMU.
1. I tried using the mmu toolchain and got errors so I figured I needed to use the previous no mmu toolchain.
2. I believe I have a good *.dts file - but followed http://www.alterawiki.com/wiki/devicetree
And I did "make menuconfig" and set up to point to it.
When I do a make I get the following:
[janet@localhost uClinux-dist]$ make
make -f tools/autotools.mk autotools-cache
make[1]: Entering directory `/home/janet/nios2-linux/uClinux-dist'
make[1]: Nothing to be done for `autotools-cache'.
make[1]: Leaving directory `/home/janet/nios2-linux/uClinux-dist'
chmod +x tools/romfs-inst.sh tools/modules-alias.sh tools/build-udev-perms.sh
. linux-2.6.x/.config; if [ "$CONFIG_INITRAMFS_SOURCE" != "" ]; then
mkdir -p `dirname $CONFIG_INITRAMFS_SOURCE`;
touch $CONFIG_INITRAMFS_SOURCE || exit 1;
fi
rm -f linux-2.6.x/usr/initramfs_data.cpio
make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- O=/home/janet/nios2-linux/uClinux-dist/linux-2.6.x -j4 -C ../linux-2.6 || exit 1
make[1]: Entering directory `/home/janet/nios2-linux/linux-2.6'
CHK include/generated/uapi/linux/version.h
GEN /home/janet/nios2-linux/uClinux-dist/linux-2.6.x/Makefile
Using /home/janet/nios2-linux/linux-2.6 as source for kernel
CHK include/generated/utsrelease.h
CALL /home/janet/nios2-linux/linux-2.6/scripts/checksyscalls.sh
<stdin>:413:2: warning:# warning syscall getrlimit not implemented
<stdin>:1208:2: warning:# warning syscall sendmmsg not implemented
<stdin>:1211:2: warning:# warning syscall setns not implemented
<stdin>:1214:2: warning:# warning syscall process_vm_readv not implemented
<stdin>:1217:2: warning:# warning syscall process_vm_writev not implemented
<stdin>:1220:2: warning:# warning syscall kcmp not implemented
CC arch/nios2/mm/cacheflush-nommu.o
CHK include/generated/compile.h
GEN usr/initramfs_data.cpio
AS usr/initramfs_data.o
DTC arch/nios2/boot/system.dtb
AS arch/nios2/boot/linked_dtb.o
LD usr/built-in.o
LD arch/nios2/boot/built-in.o
{standard input}: Assembler messages:
{standard input}:303: Error: unrecognised instruction initda
make[3]: *** [arch/nios2/mm/cacheflush-nommu.o] Error 1
make[2]: *** [arch/nios2/mm] Error 2
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/home/janet/nios2-linux/linux-2.6'
make: *** [linux] Error 1
[janet@localhost uClinux-dist]$ make menuconfig
find vendors -mindepth 2 '(' -name .svn -prune ')' -o -type f -name Kconfig -print | sed 's:^:source ../:' > vendors/Kconfig
config/mkconfig > Kconfig
KCONFIG_NOTIMESTAMP=1 /home/janet/nios2-linux/uClinux-dist/config/kconfig/mconf Kconfig# # configuration written to .config#
*** End of Linux kernel configuration.
*** Execute 'make' to build the kernel or try 'make help'.
Figure I'm doing something REALLY STUPID -- can someone make me "less stupid?"
Thanks in advance
