From my Wiki reading I'm now in the current "nios2" branch where I should be able to work with MMU and non-MMU projects.
I've got a lot of old non-mmu projects so I wanted to start there before even trying the MMU. 1. I tried using the mmu toolchain and got errors so I figured I needed to use the previous no mmu toolchain. 2. I believe I have a good *.dts file - but followed http://www.alterawiki.com/wiki/devicetree And I did "make menuconfig" and set up to point to it. When I do a make I get the following: [janet@localhost uClinux-dist]$ make make -f tools/autotools.mk autotools-cache make[1]: Entering directory `/home/janet/nios2-linux/uClinux-dist' make[1]: Nothing to be done for `autotools-cache'. make[1]: Leaving directory `/home/janet/nios2-linux/uClinux-dist' chmod +x tools/romfs-inst.sh tools/modules-alias.sh tools/build-udev-perms.sh . linux-2.6.x/.config; if [ "$CONFIG_INITRAMFS_SOURCE" != "" ]; then mkdir -p `dirname $CONFIG_INITRAMFS_SOURCE`; touch $CONFIG_INITRAMFS_SOURCE || exit 1; fi rm -f linux-2.6.x/usr/initramfs_data.cpio make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- O=/home/janet/nios2-linux/uClinux-dist/linux-2.6.x -j4 -C ../linux-2.6 || exit 1 make[1]: Entering directory `/home/janet/nios2-linux/linux-2.6' CHK include/generated/uapi/linux/version.h GEN /home/janet/nios2-linux/uClinux-dist/linux-2.6.x/Makefile Using /home/janet/nios2-linux/linux-2.6 as source for kernel CHK include/generated/utsrelease.h CALL /home/janet/nios2-linux/linux-2.6/scripts/checksyscalls.sh <stdin>:413:2: warning:# warning syscall getrlimit not implemented <stdin>:1208:2: warning:# warning syscall sendmmsg not implemented <stdin>:1211:2: warning:# warning syscall setns not implemented <stdin>:1214:2: warning:# warning syscall process_vm_readv not implemented <stdin>:1217:2: warning:# warning syscall process_vm_writev not implemented <stdin>:1220:2: warning:# warning syscall kcmp not implemented CC arch/nios2/mm/cacheflush-nommu.o CHK include/generated/compile.h GEN usr/initramfs_data.cpio AS usr/initramfs_data.o DTC arch/nios2/boot/system.dtb AS arch/nios2/boot/linked_dtb.o LD usr/built-in.o LD arch/nios2/boot/built-in.o {standard input}: Assembler messages: {standard input}:303: Error: unrecognised instruction initda make[3]: *** [arch/nios2/mm/cacheflush-nommu.o] Error 1 make[2]: *** [arch/nios2/mm] Error 2 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [sub-make] Error 2 make[1]: Leaving directory `/home/janet/nios2-linux/linux-2.6' make: *** [linux] Error 1 [janet@localhost uClinux-dist]$ make menuconfig find vendors -mindepth 2 '(' -name .svn -prune ')' -o -type f -name Kconfig -print | sed 's:^:source ../:' > vendors/Kconfig config/mkconfig > Kconfig KCONFIG_NOTIMESTAMP=1 /home/janet/nios2-linux/uClinux-dist/config/kconfig/mconf Kconfig# # configuration written to .config# *** End of Linux kernel configuration. *** Execute 'make' to build the kernel or try 'make help'. [janet@localhost uClinux-dist]$ *********************************************************************************************** Figure I'm doing something REALLY STUPID -- can someone make me "less stupid?" Thanks in advanceLink Copied
