12603 Discussions
Minor bug in altera_hps - alt_fpga_manager.c
Not sure where the correct place to post fixes are but found this minor issue. Obviously not a problem unless debugging he FPGA loading process.
49c49
< //# define dprintf(fmt, ...) printf(fmt, __VA_ARGS__)
> //#define dprintf(fmt, ...) printf(fmt,# #__VA_ARGS__)
Thank-you for reporting, I filled a bug report on it. If you spot others can you feed them to Altera using "myAltera" link on this page: https://www.altera.com/support.html (that will speed up the fix)
