12603 Discussions
Modify SDRAM Controller Cyclone ii - DE1
I generated a SDRAM Controller using the guide "Using the SDRAM on Altera’s
DE1 Board with VHDL Designs". This guide illustrate how to create a SDRAM Controller using SOPC builder in Quartus II.
It working properly but I need to generate from myself addresses where controller must write/read...
So, how can I modify the controller?I'd like modify se controller using SOPC because i easier than using code...
Any suggestion?
Thank you
Paolo
Use DMA for this task.
Thanks for your response.
Is there any guide how to implement DMA with SDRAM using SOPC?
Paolo
Yes, the are plenty. Use altera wiki and tforum search.
I searched in the forum and using altera wiki but nothing found.
Please, can you indicate me some link?
Thank you
Paolo
