12603 Discussions
My problem is, that in the Run- and Debug-Configurations the "NiosII Hardware" Section is missing (under "Run As" / "Debug As"). Only the "Local C/C++ Application" can be selected.
FENGE1
Hi there,
I am using Quartus 11.1sp2_259, and i also installed 11.1 SP2 Patch 2.11 for Windows in order to be able to use the USB-Blaster. My operating System is Windows 10.
After searching answers in the forum, I allready tried the following, but without success unfortuneately:
- Reinstalled the complete Quartus 11.1
- Running the NIOSII in compatibility mode for windows, and running it as an Administrator
- Checked if multiple USB-Blaster's are configured with "jtagconfig.exe" (only one was present)
- Generating a new "HelloWorld" project from scratch
Can you please advise me on what might be the problem with my configuration?
Thanks and best regards,
Florian Engeler
FENGE1
I nevertheless finally resolved the issue by using the windows compatibility mode. For some reason this did not work when i did it manually, but when using the windows trouble-shooter, it worked fine:
https://www.laptopmag.com/articles/set-compatibility-mode-windows-10
Ahmed_H_Intel1
Great news, I happy you solved the issue. Please let me know if you need more support.
