NIOS Avalon MM interface
AGaru1
Hi, i need to know if NIOS Avalon MM interface supports Burst transfers and what the max burstcount is. Thank you!
Isaac_V_Intel
Hello Antonio,
It is correct, NIOS Avalon MM Interface supports Burst transfer, also I'm going to attach a link [1] where you can find more information about it. At the section 3.5.5, page 30.
About the max burst count "For width of burstcount, the maximum burst length is 2(-1).The minimum legal burst length is one"
[1]. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf
Best regards
Isaac Vazquez.
Isaac_V_Intel
Hello Antonio,
Did this info works for you?
Best regards.
Isaac.
